Introduzione
You will learn how to replace your rear camera in this guide.
Lift back cover while pressing highlighted release switch towards the center of the phone.
  • Lift back cover while pressing highlighted release switch towards the center of the phone.
Aggiungi Commento
Remove the four white stickers in each corner that cover the Tri-Wing screws. Remove the white sticker near the buttons that control the volume.
  • Remove the four white stickers in each corner that cover the Tri-Wing screws.
  • Remove the white sticker near the buttons that control the volume.
  • Remove the white sticker near the SIM card.
  • Remove the big white sticker with the bar-code in the center of the phone.
Aggiungi Commento
Remove the thirteen  Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
  • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
  • Disconnect the cable near the volume buttons.
The orange circle in line with the 4 other red circles down the RH side (as shown) in the photo should be red also, as this shows a screw, not the cable (which is by the volume buttons).
Huey Smith - Replica
Hey Huey,
Nice catch! This has now been fixed.
Geoff Wacker -
Use the small plastic opening tool to pry between the screen and the rear case. Use the small plastic opening tool to pry between the screen and the rear case.
  • Use the small plastic opening tool to pry between the screen and the rear case.
Aggiungi Commento
Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard. When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
  • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Aggiungi Commento
Remove the two 2.2 mm Phillips #000 screws holding the battery cable. Use a plastic tool to remove the ribbon cable.
  • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
  • Use a plastic tool to remove the ribbon cable.
Aggiungi Commento
Use the plastic opening tool to disconnect the two antenna wires at the top of the phone. Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
  • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
  • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
Where can i find a replacemt ir blaster?
yuuki1942 - Replica
Remove the seven 3 mm Phillips #000 screws from the motherboard.
  • Remove the seven 3 mm Phillips #000 screws from the motherboard.
Aggiungi Commento
Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard. Use caution prying the ribbon cable on the right side because other ribbon cables run under it. Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
  • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
Aggiungi Commento
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone. Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables. Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
  • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
  • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
What does the orange circle refer to, as the text is a duplicate of the red circle description (and the highlighted item isn't connected with the three gate connectors)?
I think the orange circle refers to a 4th gate connector which needs to be disconnected.
Use a plastic tool to lift and remove the motherboard. Use a heat gun to loosen adhesive at bottom if needed.
  • Use a plastic tool to lift and remove the motherboard.
  • Use a heat gun to loosen adhesive at bottom if needed.
Aggiungi Commento
Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
  • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
Aggiungi Commento
Pick up and set aside vibrator, do not disconnect.
  • Pick up and set aside vibrator, do not disconnect.
Aggiungi Commento
Pull out ribbon cable.
  • Pull out ribbon cable.
  • Peel back infrared sensor.
the orange circle pointed at ribbon cable while the red pointed at infrared sensor
mohamedeldeeb69 - Replica
Lift the secondary motherboard with the camera attached. Lift the secondary motherboard with the camera attached.
  • Lift the secondary motherboard with the camera attached.
Aggiungi Commento
Use a plastic opening tool to disconnect the camera ribbon cable. Remove rear camera. Remove rear camera.
  • Use a plastic opening tool to disconnect the camera ribbon cable.
  • Remove rear camera.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Andrew Keller
Membro da: 23/09/2014
1.044 Reputazione
5 Guide realizzate
USF Tampa, Team 11-3, Blackwell Fall 2014 Membro di USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Membri
7 Guide realizzate
so..which one do i have to buy?
the Phillips #00 or the #000? the steps say one thing, the required tools section says another.
thanks in advance
alberto rivera - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 7,505
