Salta al contenuto principale
HTC One Max Motherboard Replacement
Cosa ti serve
  1. HTC One Max Motherboard Replacement, Back Case: passo 1, immagine 1 di 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Motherboard Replacement: passo 2, immagine 1 di 2 HTC One Max Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Motherboard Replacement: passo 4, immagine 1 di 2 HTC One Max Motherboard Replacement: passo 4, immagine 2 di 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Motherboard Replacement, Fingerprint Sensor: passo 5, immagine 1 di 2 HTC One Max Motherboard Replacement, Fingerprint Sensor: passo 5, immagine 2 di 2
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  6. HTC One Max Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 HTC One Max Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
  7. HTC One Max Motherboard Replacement: passo 7, immagine 1 di 2 HTC One Max Motherboard Replacement: passo 7, immagine 2 di 2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
  8. HTC One Max Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
  9. HTC One Max Motherboard Replacement: passo 9, immagine 1 di 3 HTC One Max Motherboard Replacement: passo 9, immagine 2 di 3 HTC One Max Motherboard Replacement: passo 9, immagine 3 di 3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  10. HTC One Max Motherboard Replacement: passo 10, immagine 1 di 3 HTC One Max Motherboard Replacement: passo 10, immagine 2 di 3 HTC One Max Motherboard Replacement: passo 10, immagine 3 di 3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
  11. HTC One Max Motherboard Replacement: passo 11, immagine 1 di 2 HTC One Max Motherboard Replacement: passo 11, immagine 2 di 2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
Conclusione
Altre 6 persone hanno completato questa guida.
Andrew Keller
Membro da: 09/23/14
1.131 Reputazione
5 Guide realizzate
USF Tampa, Team 11-3, Blackwell Fall 2014 Membro di USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,621
