Salta al contenuto principale
HTC One Max Battery Replacement
Cosa ti serve
  1. HTC One Max Battery Replacement, Back Case: passo 1, immagine 1 di 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Battery Replacement: passo 2, immagine 1 di 2 HTC One Max Battery Replacement: passo 2, immagine 2 di 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Battery Replacement: passo 3, immagine 1 di 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Battery Replacement: passo 4, immagine 1 di 2 HTC One Max Battery Replacement: passo 4, immagine 2 di 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Battery Replacement, Fingerprint Sensor: passo 5, immagine 1 di 2 HTC One Max Battery Replacement, Fingerprint Sensor: passo 5, immagine 2 di 2
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  6. HTC One Max Battery Replacement, Motherboard: passo 6, immagine 1 di 2 HTC One Max Battery Replacement, Motherboard: passo 6, immagine 2 di 2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
  7. HTC One Max Battery Replacement: passo 7, immagine 1 di 2 HTC One Max Battery Replacement: passo 7, immagine 2 di 2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
  8. HTC One Max Battery Replacement: passo 8, immagine 1 di 1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
  9. HTC One Max Battery Replacement: passo 9, immagine 1 di 3 HTC One Max Battery Replacement: passo 9, immagine 2 di 3 HTC One Max Battery Replacement: passo 9, immagine 3 di 3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  10. HTC One Max Battery Replacement: passo 10, immagine 1 di 3 HTC One Max Battery Replacement: passo 10, immagine 2 di 3 HTC One Max Battery Replacement: passo 10, immagine 3 di 3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
  11. HTC One Max Battery Replacement: passo 11, immagine 1 di 2 HTC One Max Battery Replacement: passo 11, immagine 2 di 2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
  12. HTC One Max Battery Replacement, IR Blaster: passo 12, immagine 1 di 1
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
  13. HTC One Max Battery Replacement: passo 13, immagine 1 di 1
    • Pick up and set aside vibrator, do not disconnect.
  14. HTC One Max Battery Replacement: passo 14, immagine 1 di 1
    • Pull out ribbon cable.
    • Peel back infrared sensor.
  15. HTC One Max Battery Replacement, Camera Board: passo 15, immagine 1 di 2 HTC One Max Battery Replacement, Camera Board: passo 15, immagine 2 di 2
    • Pull out the secondary board with the camera attached.
    • Be advised of the adhesive on the back.
  16. HTC One Max Battery Replacement, Remove Bottom Screws: passo 16, immagine 1 di 1
    • Remove two screws from the bottom.
    • Set aside metal retaining plate.
  17. HTC One Max Battery Replacement, Speaker Assembly: passo 17, immagine 1 di 2 HTC One Max Battery Replacement, Speaker Assembly: passo 17, immagine 2 di 2
    • Pry back the speaker and microphone assembly from the bottom.
    • Be careful to not poke the speaker.
  18. HTC One Max Battery Replacement, Remove Battery: passo 18, immagine 1 di 3 HTC One Max Battery Replacement, Remove Battery: passo 18, immagine 2 di 3 HTC One Max Battery Replacement, Remove Battery: passo 18, immagine 3 di 3
    • Pry the battery away from the back of the screen with a plastic tool.
    • We recommend using a heat gun to loosen the adhesive holding the battery in place.
Conclusione
Altre 15 persone hanno completato questa guida.
USF Tampa, Team 11-3, Blackwell Fall 2014 Membro di USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Membri
7 Guide realizzate
4 Commenti
Microphone in the article, battery in the title.
AaronAndrusko - Replica
How to change LCD screen for this model?
Jembalang Tanah - Replica
What the &&^& man i prefer to buy another phone %#*@ it
Russel - Replica
What the &&^& man i prefer to buy a new phone
Russel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 13
Tutti i Tempi: 15,468
