Introduzione
Be careful with the trackball.
First remove the back cover of your phone to expose the battery.
  • First remove the back cover of your phone to expose the battery.
Aggiungi Commento
Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
  • Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
Aggiungi Commento
Take the battery out When reassembling, make sure that the battery contacts match up.
  • Take the battery out
  • When reassembling, make sure that the battery contacts match up.
Aggiungi Commento
Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
  • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
Aggiungi Commento
Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
  • Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
Aggiungi Commento
Use the plastic opening tool to pry the clips off Insert the plastic opening tool along the seams at different points to it pry up This may require a bit of force. The USB port cover may fall off in this step.
  • Use the plastic opening tool to pry the clips off
  • Insert the plastic opening tool along the seams at different points to it pry up
  • This may require a bit of force. The USB port cover may fall off in this step.
Aggiungi Commento
Remove the one 3.3mm #00 screw. Remove the one 3.3mm #00 screw.
  • Remove the one 3.3mm #00 screw.
Aggiungi Commento
Use your finger or the plastic opening tool to unclip the board. Be aware of the ribbon cable connected to the motherboard inside the phone.
  • Use your finger or the plastic opening tool to unclip the board.
  • Be aware of the ribbon cable connected to the motherboard inside the phone.
Aggiungi Commento
Peel off the yellow piece of tape from the phone Peel off the yellow piece of tape from the phone
  • Peel off the yellow piece of tape from the phone
Aggiungi Commento
First flip up the retaining flap with your fingernail or a plastic opening tool. Pull on the ribbon cable gently with your fingers Pull on the ribbon cable gently with your fingers
  • First flip up the retaining flap with your fingernail or a plastic opening tool.
  • Pull on the ribbon cable gently with your fingers
Aggiungi Commento
Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable. Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
  • Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
Aggiungi Commento
Gently pull on the ribbon cable to separate the motherboard. Gently pull on the ribbon cable to separate the motherboard.
  • Gently pull on the ribbon cable to separate the motherboard.
Aggiungi Commento
Using your fingers, gently pull the trackball out. Using your fingers, gently pull the trackball out. Using your fingers, gently pull the trackball out.
  • Using your fingers, gently pull the trackball out.
Aggiungi Commento
Conclusione
Nick
Membro da: 28/10/2011
6 Reputazione
3 Guide realizzate
Cal Poly, Team 20-29, Maness Fall 2011 Membro di Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,259
