Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
  • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
  • Remove both the battery and the SD card (Press SD card in to release)
  • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
Aggiungi Commento
Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
  • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
  • Insert the flat end between the back and front enclosure, working your way around the rim.
Aggiungi Commento
Gently  depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
  • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
  • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully separate the front and back enclosures once all of the clips have been disengaged. Be sure to not separate too quickly or you risk breaking an attached tab.
  • Carefully separate the front and back enclosures once all of the clips have been disengaged.
  • Be sure to not separate too quickly or you risk breaking an attached tab.
Aggiungi Commento
Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver. Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver.
  • Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver.
Aggiungi Commento
Gently pull off the ribbons holding the sides of the motherboard to the front enclosure. Gently pull off the ribbons holding the sides of the motherboard to the front enclosure.
  • Gently pull off the ribbons holding the sides of the motherboard to the front enclosure.
Aggiungi Commento
Remove the motherboard from within the front enclosure. Be careful when pulling the ribbons off the motherboard as they may rip or break.
  • Remove the motherboard from within the front enclosure.
  • Be careful when pulling the ribbons off the motherboard as they may rip or break.
Aggiungi Commento
Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out. Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out.
  • Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out.
Aggiungi Commento
Position the phone off of the edge of the table and insert the replacement part by inserting the bevel then the trackball into the hole. Make sure the two plastic pins on the trackball bevel are oriented horizontally. Make sure the two plastic pins on the trackball bevel are oriented horizontally.
  • Position the phone off of the edge of the table and insert the replacement part by inserting the bevel then the trackball into the hole.
  • Make sure the two plastic pins on the trackball bevel are oriented horizontally.
Aggiungi Commento
Conclusione
Max Brown
Membro da: 23/01/2012
139 Reputazione
4 Guide realizzate
Cal Poly, Team 3-26, Amido Winter 2012 Membro di Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,353
