Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
  • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
  • Remove both the battery and the SD card (Press SD card in to release)
  • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
Aggiungi Commento
Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
  • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
  • Insert the flat end between the back and front enclosure, working your way around the rim.
Aggiungi Commento
Gently  depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
  • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
  • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
Aggiungi Commento
Carefully separate the front and back enclosures once all of the clips have been disengaged. Be sure to not separate too quickly or you risk breaking an attached tab.
  • Carefully separate the front and back enclosures once all of the clips have been disengaged.
  • Be sure to not separate too quickly or you risk breaking an attached tab.
Aggiungi Commento
Gently release the two ribbon cables using a plastic opening tool by  prying up the pop connectors used to attach the ribbon cables to the motherboard. Gently release the two ribbon cables using a plastic opening tool by  prying up the pop connectors used to attach the ribbon cables to the motherboard.
  • Gently release the two ribbon cables using a plastic opening tool by prying up the pop connectors used to attach the ribbon cables to the motherboard.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver. Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
  • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
Aggiungi Commento
Gently lift the motherboard out of the front enclosure once the screws are removed. Gently lift the motherboard out of the front enclosure once the screws are removed.
  • Gently lift the motherboard out of the front enclosure once the screws are removed.
Aggiungi Commento
Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out. Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out. Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out.
  • Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out.
Aggiungi Commento
Gently pry out the LCD screen from the left side of the enclosure as illustrated, using an plastic opening tool. Gently pry out the LCD screen from the left side of the enclosure as illustrated, using an plastic opening tool. Gently pry out the LCD screen from the left side of the enclosure as illustrated, using an plastic opening tool.
  • Gently pry out the LCD screen from the left side of the enclosure as illustrated, using an plastic opening tool.
Aggiungi Commento
  • Using a heat lamp or gun warm the glass in order to loosen the adhesive binding it to the frame.
Aggiungi Commento
Using a plastic opening tool, gently pry the glass from the frame by inserting the flat end between the glass and the frame from the inside of the phone. Follow the edges of the glass to ensure that all the adhesive has been released.
  • Using a plastic opening tool, gently pry the glass from the frame by inserting the flat end between the glass and the frame from the inside of the phone.
  • Follow the edges of the glass to ensure that all the adhesive has been released.
Aggiungi Commento
Once the adhesive has been released, you should be able to remove the glass by pushing on it from the inside of the phone.
  • Once the adhesive has been released, you should be able to remove the glass by pushing on it from the inside of the phone.
  • Be careful to remove the glass slowly because the ribbon cable connected to the glass is routed through the plastic frame at the bottom.
Aggiungi Commento
Carefully feed the ribbon cable through the slot in the plastic frame. Carefully feed the ribbon cable through the slot in the plastic frame. Carefully feed the ribbon cable through the slot in the plastic frame.
  • Carefully feed the ribbon cable through the slot in the plastic frame.
Aggiungi Commento
Remove any excess adhesive from the plastic frame.
  • Remove any excess adhesive from the plastic frame.
Aggiungi Commento
Conclusione
Max Brown
Membro da: 23/01/2012
139 Reputazione
4 Guide realizzate
Cal Poly, Team 3-26, Amido Winter 2012 Membro di Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,208
