Salta al contenuto principale
HTC HD2 Phone Speaker Replacement
Cosa ti serve
  1. HTC HD2 Phone Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Phone Speaker Replacement: passo 2, immagine 1 di 2 HTC HD2 Phone Speaker Replacement: passo 2, immagine 2 di 2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Phone Speaker Replacement, Midframe: passo 3, immagine 1 di 2 HTC HD2 Phone Speaker Replacement, Midframe: passo 3, immagine 2 di 2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Phone Speaker Replacement: passo 4, immagine 1 di 2 HTC HD2 Phone Speaker Replacement: passo 4, immagine 2 di 2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Phone Speaker Replacement, Phone Speaker: passo 5, immagine 1 di 1
    • With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
    • The speaker should be easily popped out of place with a small amount of force
  6. HTC HD2 Phone Speaker Replacement: passo 6, immagine 1 di 1
    • Congratulations! The speaker is now removed and can be replaced or repaired.
Conclusione
Cal Poly, Team 24-55, Amido Spring 2011 Membro di Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 6,892
