Introduzione
Replace a broken LCD with this guide.
Cosa ti serve
Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
Using the tip of your finger, lift the battery from the end closest to the camera.
Remove the battery from the rear inner frame.
Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
Remove six T5 Torx screws securing the rear inner frame to the inner case.
Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
Pry up the rear inner frame along the right edge using the method described in previous steps.
Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
Remove the single Phillips screw securing the motherboard to the inner case near the headphone jack.
Using the tip of an iPod opening tool, flip up the front-facing camera ribbon cable retaining flap.
Be very careful and gentle with these flaps. They are very easy to break or dislodge and equally difficult to reinstall.
Use a pair of tweezers to pull the front-facing camera ribbon cable straight out of its socket.
Gently lift the front-facing camera out of its recess in the inner case and remove it from the Evo.
With the heat gun set to low, start by heating the outer black border near the upper left corner of the glass panel.
Try not to excessively heat the outer plastic edge of the Evo.
Lift the front panel out of the inner case, minding the cable still routed through the bottom of the Evo.
Carefully de-route the front panel ribbon cable through the slot in the inner case.
Remove the front panel.
Notice the four (4) clear plastic hooks that are adhered behind the menu buttons. Look closely. Each one is shaped differently and in a particular orientation.
If the replacement front panel does not have these installed already, carefully remove and transfer them from the old panel to the replacement.
Peel the piece of tape connecting the underside of the LCD metal tray to the bottom of the inner case.
Altre 30 persone hanno completato questa guida.
3 Commenti
This instruction does work, I follow this and I have my phone back, the only thing now the back camera is show negative view, i reset but still the same, however the front camera does does perfect. one more thing I drop my phone and the screen crack will that be the program? and I bought the assembly screen. Very important you must use a heat gun if you going to go all the way, other wise a nice shape screw drive will do
oh, It is very good and have a lot details. Thanks for you share. For HTC Evo 4G LCD Repair Parts, you could buy in it.
