Introduzione
There are two cameras on this phone, so be sure you know which camera you are replacing before starting this guide.
Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
  • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
Aggiungi Commento
Pull out the SIM Card Tray with your fingers. Pull out the SIM Card Tray with your fingers.
  • Pull out the SIM Card Tray with your fingers.
Aggiungi Commento
Make sure the USB cover on the bottom of the phone is removed first. Starting at a corner, slowly work your way around the edge of the sides with  your prying tool to loosen the front panel.
  • Make sure the USB cover on the bottom of the phone is removed first.
  • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
Aggiungi Commento
Slowly pull the panel apart from the back of the phone.
  • Slowly pull the panel apart from the back of the phone.
  • Apply a moderate force to pry the panel from the back of the phone.
Aggiungi Commento
Set the device down so that the bottom of the phone is facing to the right.
  • Set the device down so that the bottom of the phone is facing to the right.
  • Gently take off the piece of black tape surrounding the motherboard.
  • Be careful not to rip the tape.
This tape wasn't present on my phone
Gerry Lingner - Replica
Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
  • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
Needed T4 Torx driver for this, not T5, on my phone.
Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
  • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
  • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
Aggiungi Commento
Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
  • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
Note that, in the picture, there is a hole under the connector which rests over the yellow tape removed in step 7. There may be a screw in that hole which is opposite the screw removed in step 8. You may also have a different void screw toward the bottom-left of the phone.
cmbarona - Replica
Rotate your phone back 90 Degrees counter-clockwise.
  • Rotate your phone back 90 Degrees counter-clockwise.
  • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
Aggiungi Commento
Remove the following Phillips #000 screws from the motherboard:
  • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
Aggiungi Commento
Use your pry tool to unfasten the connectors on both sides of the motherboard. The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
  • Use your pry tool to unfasten the connectors on both sides of the motherboard.
  • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
Aggiungi Commento
Use your tweezers to remove the two pieces of yellow tape shown.
  • Use your tweezers to remove the two pieces of yellow tape shown.
Aggiungi Commento
Use your tweezers to gently snap up the white board on the bottom right of the motherboard. Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
  • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
Aggiungi Commento
Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
  • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
  • Be careful not to bend the Flex Cable of the Connector.
Aggiungi Commento
Use your tweezers to gently snap the other white board on the bottom right of the motherboard up. Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
  • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
Aggiungi Commento
Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
  • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
  • Be careful not to bend the Flex Cables for the Connector.
Aggiungi Commento
Rotate the phone 180 degrees. Use your tweezers to gently snap up the white board on the top left of the motherboard.
  • Rotate the phone 180 degrees.
  • Use your tweezers to gently snap up the white board on the top left of the motherboard.
Aggiungi Commento
Use your tweezers to disconnect the cable on the top left of the motherboard.
  • Use your tweezers to disconnect the cable on the top left of the motherboard.
Aggiungi Commento
Use your tweezers to gently snap up the black board on the top left of the motherboard. Use your tweezers to gently snap up the black board on the top left of the motherboard.
  • Use your tweezers to gently snap up the black board on the top left of the motherboard.
Aggiungi Commento
Use your tweezers to gently remove the yellow connector on the top left of the phone.
  • Use your tweezers to gently remove the yellow connector on the top left of the phone.
Aggiungi Commento
Remove the long black wire on the left of the motherboard.
  • Remove the long black wire on the left of the motherboard.
Aggiungi Commento
Reorient the phone so that the green camera board is farthest from you.
  • Reorient the phone so that the green camera board is farthest from you.
  • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
Had additional screw to remove here at bottom of phone opposite location of Void screw
Use a Phillips #000 screwdriver to remove the two 3.9mm  screws on top of motherboard.
  • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
Aggiungi Commento
Now, use your fingers to slowly pull up the motherboard and remove it from the phone. Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
  • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
Aggiungi Commento
Use a Phillips #000 screwdriver to remove the two 2.1mm screws on the top of the camera board.
  • Use a Phillips #000 screwdriver to remove the two 2.1mm screws on the top of the camera board.
Aggiungi Commento
Use the pry tool along the bottom and sides of the camera board to loosen the adhesive. The power button and headphone jack need to be carefully removed with the camera board or they could snap off of the camera board.
  • Use the pry tool along the bottom and sides of the camera board to loosen the adhesive.
  • The power button and headphone jack need to be carefully removed with the camera board or they could snap off of the camera board.
Aggiungi Commento
Slowly lift the camera board up and work on removing the remaining adhesive. You can then take the camera board off of the phone.
  • Slowly lift the camera board up and work on removing the remaining adhesive. You can then take the camera board off of the phone.
Aggiungi Commento
Use your tweezers to gently pull off the two pieces of yellow tape in the center of the camera board. Use your tweezers to gently pull off the two pieces of yellow tape in the center of the camera board.
  • Use your tweezers to gently pull off the two pieces of yellow tape in the center of the camera board.
Aggiungi Commento
Use your tweezers to gently flip the white connector board into the upright position. Use your tweezers to gently flip the white connector board into the upright position.
  • Use your tweezers to gently flip the white connector board into the upright position.
Aggiungi Commento
Use your tweezers to remove the rear-facing camera from the camera board.
  • Use your tweezers to remove the rear-facing camera from the camera board.
Aggiungi Commento
Conclusione
Cal Poly, Team 4-43, Amido Fall 2014 Membro di Cal Poly, Team 4-43, Amido Fall 2014
CPSU-AMIDO-F14S4G43
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 868
