Introduzione
If the front facing camera has become nonfunctional, it may be replaced. It is easy to check if the front facing camera is faulty; if the screen does not display an image when the front facing camera is activated via the camera application, then it is likely faulty and responsible. It may be replaced by following this step-by-step guide.
Use the spudger to pry the back cover off.
  • Use the spudger to pry the back cover off.
Aggiungi Commento
Use  spudger tool to pry under the battery to lift it up and out.
  • Use spudger tool to pry under the battery to lift it up and out.
Aggiungi Commento
Remove eight 8.3mm T4  screws with the  Torx screwdriver.
  • Remove eight 8.3mm T4 screws with the Torx screwdriver.
Aggiungi Commento
Pry the back panel of the screen using the plastic opener.
  • Pry the back panel of the screen using the plastic opener.
  • Work your way gently around the device, using picks as necessary to keep the back panel separated.
  • Use caution not to damage the device, as it takes force to remove the rear panel.
Aggiungi Commento
Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
Aggiungi Commento
Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
Aggiungi Commento
Remove volume control button ribbon with tweezers.
  • Remove volume control button ribbon with tweezers.
Aggiungi Commento
Carefully remove the ribbon attached to the top of the motherboard.
  • Carefully remove the ribbon attached to the top of the motherboard.
Aggiungi Commento
Unsnap the wire from the printed circuit board (PCB) using the tweezers.
  • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
Aggiungi Commento
Remove the camera using the plastic opening tool as shown.
  • Remove the camera using the plastic opening tool as shown.
Aggiungi Commento
Conclusione
Steven Pate
Membro da: 23/09/2014
191 Reputazione
7 Guide realizzate
USF Tampa, Team 9-3, Blackwell Fall 2014 Membro di USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 595
