Introduzione
If the indicator button on the top of the phone illuminates when plugged in to charge but the battery does not hold a charge when unplugged, the battery is likely in need of replacement. This guide shows the step-by-step procedure involved in replacing the battery of the device. The back cover is easily removed using a spudger or the fingertips, allowing easy access to the battery as shown below. Note: do not replace with a third party battery. They have been shown to overheat and damage the device, and are generally unsafe.
Parti
Nessuna parte richiesta.
Use the spudger to pry the back cover off.
  • Use the spudger to pry the back cover off.
Aggiungi Commento
Use  spudger tool to pry under the battery to lift it up and out.
  • Use spudger tool to pry under the battery to lift it up and out.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Steven Pate
Membro da: 23/09/2014
191 Reputazione
7 Guide realizzate
USF Tampa, Team 9-3, Blackwell Fall 2014 Membro di USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,687
