Slide the silver release tab up and simultaneously lift the cover up from the left side.
  • Slide the silver release tab up and simultaneously lift the cover up from the left side.
Aggiungi Commento
Push the tab from left to right to remove the cover.
  • Push the tab from left to right to remove the cover.
Aggiungi Commento
Now lift the battery up and away from the device to remove it.
  • Now lift the battery up and away from the device to remove it.
Aggiungi Commento
Remove the four silver screws (T5 x .25 in).
  • Remove the four silver screws (T5 x .25 in).
Aggiungi Commento
Remove the single black screw (T5 x .125 in) beneath the HP sticker.
  • Remove the single black screw (T5 x .125 in) beneath the HP sticker.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Next, use your plastic removal tool to separate the gray back from the black center piece. For better results, start the separation at the corner piece.
  • Next, use your plastic removal tool to separate the gray back from the black center piece.
  • For better results, start the separation at the corner piece.
Aggiungi Commento
Remove the back case.
  • Remove the back case.
Aggiungi Commento
Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
  • Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
Aggiungi Commento
Next you will need to unlock and remove the ribbon cable Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
  • Next you will need to unlock and remove the ribbon cable
  • Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
  • The bar, connector, and cable are fragile components that can be easily broken
Aggiungi Commento
Next you need to remove the wire off the bottom of the mother board The easiest method is to use some metal tweezers and grip the plug close to the connector.
  • Next you need to remove the wire off the bottom of the mother board
  • The easiest method is to use some metal tweezers and grip the plug close to the connector.
  • Make sure all these connections are properly disconnected before separation of the motherboard
Aggiungi Commento
Next use your plastic removal tool and separate the silver front case from the black frame.
  • Next use your plastic removal tool and separate the silver front case from the black frame.
Aggiungi Commento
Now that the front cover is removed we will need to disconnect the LCD screen from the mother board. Pull the LCD connection out of the slot to properly disconnect.
  • Now that the front cover is removed we will need to disconnect the LCD screen from the mother board. Pull the LCD connection out of the slot to properly disconnect.
Aggiungi Commento
Next we will need to remove the last wire from the motherboard
  • Next we will need to remove the last wire from the motherboard
  • The easiest method is to grab and pull with metal tweezers near the bottom of the plug near the connector.
Aggiungi Commento
Finally the mother board can be removed from the center black frame. Finally the mother board can be removed from the center black frame.
  • Finally the mother board can be removed from the center black frame.
Aggiungi Commento
Conclusione
John Pagliero
Membro da: 27/01/2011
886 Reputazione
7 Guide realizzate
Cal Poly, Team 3-39, Regan Winter 2011 Membro di Cal Poly, Team 3-39, Regan Winter 2011
CPSU-REGAN-W11S3G39
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 759
