Parti
Nessuna parte richiesta.
Flip the HP iPAQ HW6515 over with the screen facing down. Take the back cover off by pressing on the small silver button while pulling back then up on the case. Place the back of the case aside for now.
  • Flip the HP iPAQ HW6515 over with the screen facing down.
  • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
  • Place the back of the case aside for now.
Aggiungi Commento
Remove the battery by pulling up on the black tab.
  • Remove the battery by pulling up on the black tab.
Aggiungi Commento
Unscrew the four screws using the T6 hexagonal star screwdriver. Unscrew the middle screw using the Phillips 00 screwdriver. "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
  • Unscrew the four screws using the T6 hexagonal star screwdriver.
  • Unscrew the middle screw using the Phillips 00 screwdriver.
  • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
Aggiungi Commento
Use the plastic opening tool to pry apart the covers along the bottom of the phone. Slide the plastic opening tool along the seam until the two halves of the case separate. Slide the plastic opening tool along the seam until the two halves of the case separate.
  • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
  • Slide the plastic opening tool along the seam until the two halves of the case separate.
Aggiungi Commento
Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire. Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
  • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
Aggiungi Commento
Gently pull off the black rubber square covering the LED light. The LED is now exposed. Wedge the plastic opening tool under the LED to pop it out and expose its wire.
  • Gently pull off the black rubber square covering the LED light.
  • The LED is now exposed.
  • Wedge the plastic opening tool under the LED to pop it out and expose its wire.
  • Using your index finger and thumb, unplug the wire from the phone and remove the LED.
Aggiungi Commento
Conclusione
Steven Vo
Membro da: 02/04/2012
33 Reputazione
1 Guida realizzata
Cal Poly, Team 15-17, Forte Spring 2012 Membro di Cal Poly, Team 15-17, Forte Spring 2012
CPSU-FORTE-S12S15G17
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,036
