Introduzione
Before replacing your hard drive make sure you have backed up all of your files and have an OS install disk on hand. Now you're ready to replace your hard drive!
Parti
Nessuna parte richiesta.
Ensure your computer is shut down.
  • Ensure your computer is shut down.
  • Removing the battery while the laptop is still on may corrupt your files.
  • Remove any power adapters and cords connected to the laptop body.
  • Turn the computer over so the bottom is facing up.
  • These pictures show no battery, but your battery should still be in your computer at this point.
Aggiungi Commento
The battery release is below the bottom right corner of the battery bay.
  • The battery release is below the bottom right corner of the battery bay.
  • Slide the switch to the right until the release clicks.
Aggiungi Commento
Remove the battery.
  • Remove the battery.
  • The release switch may need to be held down while removing the battery.
Aggiungi Commento
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver. Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Aggiungi Commento
Remove the plastic hard drive cover.
  • Remove the plastic hard drive cover.
Aggiungi Commento
Pull up on the two plastic flaps on the hard drive enclosure to remove it. Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
Aggiungi Commento
Gently lift the ribbon cable away from the hard drive enclosure to free the drive. Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
Aggiungi Commento
Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver. Slide the hard drive out of the enclosure to complete the removal process.
  • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
  • Slide the hard drive out of the enclosure to complete the removal process.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Nick Loey
Membro da: 01/04/2014
1.535 Reputazione
8 Guide realizzate
Cal Poly, Team 9-15, Regan Spring 2014 Membro di Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,048
