Salta al contenuto principale
HP ZBook 15 Wi-Fi Card Replacement
Cosa ti serve
  1. HP ZBook 15 Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 2 HP ZBook 15 Wi-Fi Card Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Wi-Fi Card Replacement, Back Cover: passo 2, immagine 1 di 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 1 di 1
    • Lift up the two tabs connected to wires.
  4. HP ZBook 15 Wi-Fi Card Replacement: passo 4, immagine 1 di 2 HP ZBook 15 Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Remove the two 3mm screws from the corners of the card with a Phillips #0 screwdriver.
    • Lift the card up and slide it out to disconnect it.
Conclusione
Altre 3 persone hanno completato questa guida.
Grant Terris
Membro da: 01/30/15
2.828 Reputazione
12 Guide realizzate
Cal Poly, Team 8-43, Amido Winter 2015 Membro di Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Membri
15 Guide realizzate
Un commento
I’m planning to upgrade my Zbook by installing a Wireless AC-capable WiFi module. I’ve found a cheap one that’s compatible according to the service manual: the Intel 7260HMW. However, it doesn’t have an HP SPS, it seems to have come from a DELL laptop.
Has anyone tried this? Will it work? I guess I’ll find out the hard way!
Hopefully, the seller will allow me to test the adapter before buying.
Luis Alejandro Araúz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 5,448
