Introduzione
Does your computer feel warmer than usual? Here are some reasons why your laptop might be running hot. If you determine that you need to replace the fan or heatsink assembly, follow this guide!
Flip the laptop over. Slide the lever with the battery symbol beside it firmly until the battery pops out.
  • Flip the laptop over.
  • Slide the lever with the battery symbol beside it firmly until the battery pops out.
  • Remove the battery from the laptop.
Aggiungi Commento
Slide the right lever firmly to the right.
  • Slide the right lever firmly to the right.
  • Slide the cover towards yourself to remove it.
Aggiungi Commento
Remove the two 16mm screws with a Phillips #0 screwdriver.
  • Remove the two 16mm screws with a Phillips #0 screwdriver.
  • There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again.
Note that it is not necessary to completely remove these screws. They are meant to be 'captive' and not removed completely. If you unscrew them to that 'first thread' so they are loose and floppy, they are no longer holding the keyboard in place and it is safe to continue to the next step.
Joe Kyle - Replica
Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side.  Metal inserts on the bottom side lock the keyboard in place  until they are slid up and out. Be careful not to scratch or chip the computer when prying.  If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool. There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
  • Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side. Metal inserts on the bottom side lock the keyboard in place until they are slid up and out.
  • Be careful not to scratch or chip the computer when prying. If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool.
  • There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
  • Flip the laptop over so the keyboard is visible.
  • Insert the spudger under the left side of the keyboard.
    • Carefully raise the side of the keyboard and firmly pull the left corner of the keyboard until it pops up.
    • Run your fingers under the edges of the keyboard along the top edge of the keyboard, from the top left to the top right, to separate it from the remaining clips.
  • Carefully slide the keyboard up toward the screen and out of the case.
Please keep in mind that the keyboard comes with a metal plate. If you managed to pry one of the plastic rivets out of the keyboard, you've damaged the keyboard...
(I should have read the comments about taking the optical drive out first, haha...)
Brandon Lu - Replica
Gently lift the two tabs on either side of the black ribbon with a spudger until the ribbon comes loose. Disconnect the black ribbon by pulling the blue tab hanging off of it. Repeat with the white ribbon.
  • Gently lift the two tabs on either side of the black ribbon with a spudger until the ribbon comes loose.
  • Disconnect the black ribbon by pulling the blue tab hanging off of it.
  • Repeat with the white ribbon.
Aggiungi Commento
Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
  • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
  • The screw does not come out all the way and stays attached to the computer.
Missed 3 screws to be removed before pushing the optical drive!
Vincent Rouillard - Replica
Actually there are 4 screws
Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case. Once the drive is protruding from the side of the computer, pull it the rest of the way out. Once the drive is protruding from the side of the computer, pull it the rest of the way out.
  • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
  • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
Aggiungi Commento
Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
  • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
  • The screws will remain inside the springs of the hard drive caddy cover.
Aggiungi Commento
Pull the green tab away from the metal casing and lift the drive out. Pull the green tab away from the metal casing and lift the drive out.
  • Pull the green tab away from the metal casing and lift the drive out.
Aggiungi Commento
Unscrew two 3mm screws from the hard drive bay with a Phillips #0 screwdriver.
  • Unscrew two 3mm screws from the hard drive bay with a Phillips #0 screwdriver.
Aggiungi Commento
Remove the eight 6mm screws with a T8 Torx screwdriver.
  • Remove the eight 6mm screws with a T8 Torx screwdriver.
Aggiungi Commento
Rotate the laptop so the battery compartment is in front of you.
  • Rotate the laptop so the battery compartment is in front of you.
  • Remove the four 4 mm screws under the battery with a T8 Torx screwdriver.
Aggiungi Commento
Remove three more 4mm screws from the optical drive compartment with a T8 Torx screwdriver.
  • Remove three more 4mm screws from the optical drive compartment with a T8 Torx screwdriver.
Aggiungi Commento
Flip the laptop so it is keyboard side up.
  • Flip the laptop so it is keyboard side up.
  • Remove the 6mm screw with a T8 Torx screwdriver.
Aggiungi Commento
Use a spudger to lift the edges of the connector up so the white ribbon can slide out.
  • Use a spudger to lift the edges of the connector up so the white ribbon can slide out.
  • Pull the ribbons out by the blue plastic tab on the cable at each connector site.
Aggiungi Commento
There are still ribbons that need to be removed before the top cover separates completely; do not yank the cover off after it is separated to prevent ripping the cables out.
  • There are still ribbons that need to be removed before the top cover separates completely; do not yank the cover off after it is separated to prevent ripping the cables out.
  • Start at the front of the latop and run a plastic spudger between the top cover and the case to undo the clips holding it together
  • If there is difficulty separating the top cover from the computer, do not force it. You might have missed a screw.
Aggiungi Commento
Angle the top cover so you can see the white ribbons shown in the picture. Carefully slide the top cover toward you to expose the white ribbon connectors.
  • Angle the top cover so you can see the white ribbons shown in the picture.
  • Carefully slide the top cover toward you to expose the white ribbon connectors.
  • Use a spudger to lift the connectors and slide out both ribbons.
Aggiungi Commento
Unscrew the eight captive screws with a T9 Torx screwdriver.
  • Unscrew the eight captive screws with a T9 Torx screwdriver.
  • Undo the screws in the order represented by the small numbers next to the screw on the heat sink assembly. Repeat this while reassembling to prevent damage to the components underneath.
  • These screws will also not unscrew all the way.
Aggiungi Commento
Gently pull up on the 4 pin fan power connector cable to unplug it from the system.
  • Gently pull up on the 4 pin fan power connector cable to unplug it from the system.
Aggiungi Commento
Gently lift the fan and heatsink assembly straight up and out so you do not smear the thermal paste.
  • Gently lift the fan and heatsink assembly straight up and out so you do not smear the thermal paste.
  • Thermal paste is a heat conductive gel applied to the underside of the heatsinks. Be careful not to wipe any off or else the components within the laptop will not cool properly and could become damaged. It also makes a big sticky mess if it smears or gets on any other components.
Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
Grant Terris
Membro da: 30/01/2015
1.905 Reputazione
12 Guide realizzate
Cal Poly, Team 8-43, Amido Winter 2015 Membro di Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Membri
12 Guide realizzate
Wow, looks like that graphics card is actually user replaceable? That’s really awesome to see, with both the CPU being socketed and GPU being on a slot, that makes this system super upgradable and (hopefully) long lasting. If you manage to burn your GPU out, you don’t have to replace the entire motherboard.
Shane Roeseberg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 71
Ultimi 30 Giorni: 299
Tutti i Tempi: 9,469
