Introduzione
Use this guide to replace the motherboard.
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
  • In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
  • The front panel is held in by seven clips (boxed in red) that are lightly anchored to the rear case. When you remove the front panel assembly, you are bound to break either the clips or their supports attached to the rear case. We will update this guide as we find replacement parts or a better method to remove the panel.
  • As you remove the front panel assembly, also be careful not to damage the ambient light sensor (boxed in yellow) or the two antennas (boxed in orange).
Beware of the ribbon cable right beneath the volume rocker, as it's easy to shear that cable if you are too rough with the metal spudger.
Michael Innes - Replica
I wasn’t happy with using a metal spudger as it felt a bit forceful, as I have a bulk pack of opening tools I tried using them instead.
I may have been lucky, but by using those tools instead with the angled lip facing inwards at points adjacent to where the mounting clips are located according to the above image (like this, https://i.imgur.com/dylp6BG.jpg ), I managed to open the unit without breaking a clip or scratching the plastic back panel by bending the outside of the panel enough to pop the lcd panel.
Michael Sim - Replica
Insert a flat metal spudger in the gap between the rubber outer ring on the front panel assembly and the black plastic rear case near the USB connector.
  • Insert a flat metal spudger in the gap between the rubber outer ring on the front panel assembly and the black plastic rear case near the USB connector.
  • Pry the front panel assembly up from the rear case, being careful not to damage the LCD or the glass panel.
  • As you work through the following steps, insert your metal spudger and pry the front panel up, but do not try to slide the spudger along the gap you're creating. Always remove your spudger, then insert it at another spot and pry upward.
Aggiungi Commento
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad. Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
  • As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
  • Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Aggiungi Commento
Pry up the front panel assembly along the top edge of the TouchPad. Be careful not to damage the ambient light sensor or the upper antenna.
  • Pry up the front panel assembly along the top edge of the TouchPad.
  • Be careful not to damage the ambient light sensor or the upper antenna.
Aggiungi Commento
Pry up the front panel along the edge closest to the home screen button.
  • Pry up the front panel along the edge closest to the home screen button.
Aggiungi Commento
Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down. Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
  • Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down.
  • Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
Aggiungi Commento
After freeing the retaining clips, lift the front panel assembly away from the rear case.
  • After freeing the retaining clips, lift the front panel assembly away from the rear case.
  • Do not try to remove the front panel assembly from the TouchPad just yet, as it is still connected to the motherboard.
Aggiungi Commento
Use the attached black tab to pull the display data cable straight up and out of its socket on the motherboard.
  • Use the attached black tab to pull the display data cable straight up and out of its socket on the motherboard.
  • Pull the cable upwards and not parallel to the face of the motherboard. Doing otherwise may damage the socket on the motherboard.
  • Take care not to pull on the ribbon that is stuck by adhesive to the bottom of cable you are detaching. It does not need to be disconnected.
The ribbon can be adhered to other parts placed under it. You'll have to separate them tighly so you don't damage the ribbon.
Laurent - Replica
Use your fingernail to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets. Be sure you are prying up on the hinged retaining flaps, not the sockets themselves. Pull the digitizer ribbon cable straight out of its two sockets on the motherboard.
  • Use your fingernail to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
  • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
  • Pull the digitizer ribbon cable straight out of its two sockets on the motherboard.
Aggiungi Commento
Remove the front panel assembly from the rear case assembly.
  • Remove the front panel assembly from the rear case assembly.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Use the edge of a plastic opening tool to peel up the two pieces of copper tape covering the USB connector board near the battery and the motherboard. Use the edge of a plastic opening tool to peel up the two pieces of copper tape covering the USB connector board near the battery and the motherboard.
  • Use the edge of a plastic opening tool to peel up the two pieces of copper tape covering the USB connector board near the battery and the motherboard.
Aggiungi Commento
Remove the four 3.2 mm Phillips screws securing the USB connector board to the rear case.
  • Remove the four 3.2 mm Phillips screws securing the USB connector board to the rear case.
Aggiungi Commento
Pry the upper end of the USB connector board upwards to disconnect it from its socket on the logic board.
  • Pry the upper end of the USB connector board upwards to disconnect it from its socket on the logic board.
Aggiungi Commento
Pull the USB connector board away from the bottom edge of the rear case and lift, but do not remove it out of its housing.
  • Pull the USB connector board away from the bottom edge of the rear case and lift, but do not remove it out of its housing.
  • The USB connector board is still attached to the vibrator motor. Do not completely remove the USB connector board just yet.
Aggiungi Commento
Pull the vibrator motor connector straight away from its socket on the USB connector board. Remove the USB connector board from the TouchPad. NOTE: First verify that there is a connector before pulling! The vibrator motor may be soldered directly to the USB Board requiring the motor to be pried up and removed together with the board.
  • Pull the vibrator motor connector straight away from its socket on the USB connector board.
  • Remove the USB connector board from the TouchPad.
  • NOTE: First verify that there is a connector before pulling! The vibrator motor may be soldered directly to the USB Board requiring the motor to be pried up and removed together with the board.
This piece may be soldered. If that is the case, just leave it connected and move the USB connector board aside
combsste - Replica
If present, remove the two pieces of tape boxed in red.
  • If present, remove the two pieces of tape boxed in red.
Aggiungi Commento
Use the edge of a plastic opening tool to flip up the retaining flap on the volume control/power button ribbon cable socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use the edge of a plastic opening tool to flip up the retaining flap on the volume control/power button ribbon cable socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Pull the cable out of its socket.
Aggiungi Commento
Use a plastic opening tool to lift the camera connector up and out of its socket on the motherboard.
  • Use a plastic opening tool to lift the camera connector up and out of its socket on the motherboard.
  • Bend the camera cable away from the motherboard.
Aggiungi Commento
Carefully flip up the retaining flap on the microphone cable socket. Be sure you are prying up on the hinged retaining flap.
  • Carefully flip up the retaining flap on the microphone cable socket.
  • Be sure you are prying up on the hinged retaining flap.
  • Pull the microphone cable out of its socket.
Its just a reminder when you're repairing your touchpad back to the way it was ( reversing the steps) It might be difficult to place your microphone ribbon back into its socket. Would advise to use some sort of device ( like tweezers) to help place it back inside its socket. Just be gentle.
Frank Booker - Replica
Use your plastic opening tool to pry the upper antenna connector up from its socket on the motherboard.
  • Use your plastic opening tool to pry the upper antenna connector up from its socket on the motherboard.
Aggiungi Commento
Pry up the retaining flap on the headphone jack ribbon cable socket. Be sure you are prying up on the hinged retaining flap.
  • Pry up the retaining flap on the headphone jack ribbon cable socket.
  • Pull the headphone jack ribbon cable out of its socket.
Aggiungi Commento
Pry the speaker cable connector up from its socket on the motherboard.
  • Pry the speaker cable connector up from its socket on the motherboard.
  • Pry up from beneath the wires.
Aggiungi Commento
Use a plastic opening tool to flip up the retaining flap on the digitizer board ribbon cable socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use a plastic opening tool to flip up the retaining flap on the digitizer board ribbon cable socket.
  • Pull the digitizer ribbon cable out of its socket.
Aggiungi Commento
Pry up the lower antenna cable connector from its socket on the motherboard.
  • Pry up the lower antenna cable connector from its socket on the motherboard.
Aggiungi Commento
De-route the lower antenna cable along the top edge of the battery and carefully pull it out from under its retaining clip near the top right corner of the battery.
  • De-route the lower antenna cable along the top edge of the battery and carefully pull it out from under its retaining clip near the top right corner of the battery.
Aggiungi Commento
Remove the eight 3.2 mm Phillips screws securing both the battery and the motherboard to the rear case.
  • Remove the eight 3.2 mm Phillips screws securing both the battery and the motherboard to the rear case.
Aggiungi Commento
Use a plastic opening tool to pry the battery up from the tape securing it to the rear case. It is easiest to pry up along the edges of the battery closest to the USB connector and the digitizer board.
  • Use a plastic opening tool to pry the battery up from the tape securing it to the rear case.
  • It is easiest to pry up along the edges of the battery closest to the USB connector and the digitizer board.
The battery may be tightly adhered to the copper foil beneath. Take care not to damage this foil or the battery charging coil beneath it.
jsifert Macs - Replica
Lift the motherboard assembly out of the rear case, minding any cables that may get caught.
  • Lift the motherboard assembly out of the rear case, minding any cables that may get caught.
ok but wat abt d battery man
harineteddy - Replica
Carefully pull the battery away from the L-shaped motherboard to disconnect its cable. Remove the battery from the motherboard.
  • Carefully pull the battery away from the L-shaped motherboard to disconnect its cable.
  • Remove the battery from the motherboard.
Aggiungi Commento
Motherboard remains.
  • Motherboard remains.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 10,818
