Introduzione
The laptop needs to be turned off during this procedure. Disconnecting the battery while the laptop is powered on may hurt you or damage your laptop.
Cosa ti serve
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
Remove the six 4 mm screws using a Phillips #000 screwdriver.
Quasi finito!
Conclusione
