Introduzione
This guide should be able to help you replace the microphone if not working properly on your HP device. By following these steps you should have it replaced or fixed in not time.
Parti
Nessuna parte richiesta.
Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
  • Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
  • Unplug your tablet from any power supply
  • Remove all external devices.
  • Remove back cover with plastic tools to avoid scratching the screen.
Aggiungi Commento
Remove all screws from the sides of the battery
  • Remove all screws from the sides of the battery
Aggiungi Commento
Disconnect the battery cable from the system board.
  • Disconnect the battery cable from the system board.
  • Use a little bit of pressure to remove the cable.
Aggiungi Commento
Release the ZIF connector to which the microphone cable is attached
  • Release the ZIF connector to which the microphone cable is attached
Aggiungi Commento
Remove microphone from panel using tweezers
  • Remove microphone from panel using tweezers
  • Add your new microphone
Aggiungi Commento
Conclusione
Claudia
Membro da: 31/08/2014
246 Reputazione
2 Guide realizzate
USF Tampa, Team 9-4, Blackwell Fall 2014 Membro di USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 302
