Introduzione
This guide will show you how to replace your HP Slate 8 Pro battery.
Parti
Nessuna parte richiesta.
Secure the suction cup to the center of the device’s screen. Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
  • Secure the suction cup to the center of the device’s screen.
  • Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
Aggiungi Commento
Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place. Use the tweezers to pull the flat, yellow cable out of its connectors.
  • Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place.
    • Use the tweezers to pull the flat, yellow cable out of its connectors.
  • Use the tweezers to disconnect the battery connector from the circuit board.
  • Using the spudger tool again, pry up and release the connectors at the ends of the flat, orange cable.
    • Remove the flat, orange cable.
Aggiungi Commento
As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
  • As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
Aggiungi Commento
Grasp the battery and remove it from the device.
  • Grasp the battery and remove it from the device.
  • Do not attempt to open or tamper with the battery. This could result in injury.
Aggiungi Commento
Conclusione
Jose Revelo
Membro da: 23/09/2014
305 Reputazione
3 Guide realizzate
USF Tampa, Team 9-4, Blackwell Fall 2014 Membro di USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 36
Tutti i Tempi: 2,088
