Salta al contenuto principale
HP ProBook 450 G4 Keyboard Replacement
Cosa ti serve
  1. HP ProBook 450 G4 Keyboard Replacement, Hard Drive: passo 1, immagine 1 di 2 HP ProBook 450 G4 Keyboard Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Keyboard Replacement: passo 2, immagine 1 di 3 HP ProBook 450 G4 Keyboard Replacement: passo 2, immagine 2 di 3 HP ProBook 450 G4 Keyboard Replacement: passo 2, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Keyboard Replacement: passo 3, immagine 1 di 2 HP ProBook 450 G4 Keyboard Replacement: passo 3, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Keyboard Replacement: passo 4, immagine 1 di 2 HP ProBook 450 G4 Keyboard Replacement: passo 4, immagine 2 di 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 3 HP ProBook 450 G4 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 3 HP ProBook 450 G4 Keyboard Replacement, Keyboard: passo 5, immagine 3 di 3
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Keyboard Replacement: passo 6, immagine 1 di 3 HP ProBook 450 G4 Keyboard Replacement: passo 6, immagine 2 di 3 HP ProBook 450 G4 Keyboard Replacement: passo 6, immagine 3 di 3
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Keyboard Replacement: passo 7, immagine 1 di 3 HP ProBook 450 G4 Keyboard Replacement: passo 7, immagine 2 di 3 HP ProBook 450 G4 Keyboard Replacement: passo 7, immagine 3 di 3
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Keyboard Replacement: passo 8, immagine 1 di 2 HP ProBook 450 G4 Keyboard Replacement: passo 8, immagine 2 di 2
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
Conclusione
Sebastian Dow
Membro da: 01/23/20
1.007 Reputazione
6 Guide realizzate
Cal Poly, Team S1-G3, White Winter 2020 Membro di Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 150
Tutti i Tempi: 6,108
