Introduzione
If your computer is always over heating due to the fan not properly cooling down the internal components, then you may need to replace the fan. The fan allows for air circulation throughout the computer.
Parti
Nessuna parte richiesta.
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in. Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Aggiungi Commento
Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver). Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
Aggiungi Commento
Flip laptop over and open it.
  • Flip laptop over and open it.
Aggiungi Commento
Slightly push up while lifting up on the power button panel to release the panel.
  • Slightly push up while lifting up on the power button panel to release the panel.
Aggiungi Commento
Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Aggiungi Commento
Carefully (holding both sides of the keyboard), push up and lift slightly. Keyboard is still connected via a ribbon cable.
  • Carefully (holding both sides of the keyboard), push up and lift slightly.
  • Keyboard is still connected via a ribbon cable.
  • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Aggiungi Commento
Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Aggiungi Commento
Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
Aggiungi Commento
Carefully slide the bottom panel to the right.
  • Carefully slide the bottom panel to the right.
  • Keyboard is connected via a wire to the back of the panel.
Aggiungi Commento
Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
  • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
  • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
Aggiungi Commento
Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
Aggiungi Commento
Locate silver holding panel on the left side of the computer.
  • Locate silver holding panel on the left side of the computer.
Aggiungi Commento
Unscrew the five silver (2.5 mm Phillips)  screws that are holding the panel in.
  • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
  • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
Aggiungi Commento
Remove holding panel and put aside.
  • Remove holding panel and put aside.
Aggiungi Commento
Disconnect the red, black, and blue ribbon cable connector using the black spudger.
  • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
Aggiungi Commento
Unscrew the one (2.0 mm Phillips) screw holding in the fan.
  • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
Aggiungi Commento
Lift fan up carefully and replace.
  • Lift fan up carefully and replace.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Eric Markham
Membro da: 29/08/2014
182 Reputazione
4 Guide realizzate
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro di USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 803
