Shut the device off. Lift the top cover of the scanner. Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Shut the device off.
  • Lift the top cover of the scanner.
  • Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Pull the frame out.
Aggiungi Commento
Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
  • Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
Aggiungi Commento
Pushing the clip behind the cover piece in, pull the cover piece outwards. Pushing the clip behind the cover piece in, pull the cover piece outwards.
  • Pushing the clip behind the cover piece in, pull the cover piece outwards.
Aggiungi Commento
Remove the two screws on the front of the printer with a T10 screwdriver. The first is inside the power button panel space and the second is across the printer slider.
  • Remove the two screws on the front of the printer with a T10 screwdriver.
    • The first is inside the power button panel space and the second is across the printer slider.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Pull the circuit board from the power button panel space.
  • Pull the circuit board from the power button panel space.
  • Unplug the small ribbon cable from the circuit board.
Aggiungi Commento
Pull the memory card reader's circuit board out of its slot. Detach the rainbow connector from the back of the circuit board.
  • Pull the memory card reader's circuit board out of its slot.
  • Detach the rainbow connector from the back of the circuit board.
Aggiungi Commento
Press the clip directly behind the TouchSmart panel and pull the panel up. Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Press the clip directly behind the TouchSmart panel and pull the panel up.
  • Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Do not hesitate to use force to remove the TouchSmart panel.
Aggiungi Commento
Grip the printer hood and pull upward.
  • Grip the printer hood and pull upward.
Aggiungi Commento
With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
  • With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
Aggiungi Commento
With the glass facing upwards, remove the screw holding the glass in place. With the glass facing upwards, remove the screw holding the glass in place.
  • With the glass facing upwards, remove the screw holding the glass in place.
Aggiungi Commento
Lift the glass up and away from the printer.
  • Lift the glass up and away from the printer.
  • Handle glass with care.
  • Replace the broken glass piece with the replacement glass
Aggiungi Commento
Conclusione
garrett hall
Membro da: 26/09/2012
19 Reputazione
2 Guide realizzate
Cal Poly, Team 2-11, Propen Fall 2012 Membro di Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,292
