Parti
Nessuna parte richiesta.
Before disassembling your printer, be sure that the printer has been unplugged. Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
  • Before disassembling your printer, be sure that the printer has been unplugged.
  • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
  • Remove the two T10 12mm Torx screws from the left side panel.
Aggiungi Commento
Firmly pull the the back of the side panel until it separates from the body of the printer. Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  • Firmly pull the the back of the side panel until it separates from the body of the printer.
  • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
Aggiungi Commento
Rotate the printer 90 degrees clockwise. Grasp the paper tray and rotate it down.
  • Rotate the printer 90 degrees clockwise.
  • Grasp the paper tray and rotate it down.
  • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
Aggiungi Commento
Rotate the printer 90 degrees clockwise. Remove the two T10 12 mm Torx screws.
  • Remove the two T10 12 mm Torx screws.
  • Grasp both sides of the side panel and pull it forward to remove the panel.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Rotate the printer 90 degrees counter clockwise. Lift the scanner lid to expose the scanner glass.
  • Rotate the printer 90 degrees counter clockwise.
  • Lift the scanner lid to expose the scanner glass.
Aggiungi Commento
  • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
Aggiungi Commento
Rotate the printer 90 degrees counter clockwise. Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
  • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
  • Remove the front panel by grasping its front and pulling away from the printer.
Aggiungi Commento
Rotate the printer 90 degrees clockwise. Remove the cable connecting the top panel of the printer to the power button assembly.
  • Remove the cable connecting the top panel of the printer to the power button assembly.
Aggiungi Commento
Carefully lift the top panel of the printer away from the printer body.
  • Carefully lift the top panel of the printer away from the printer body.
Aggiungi Commento
Set aside the printer body. Unscrew the T10 12 mm Torx screw.
  • Set aside the printer body.
  • Unscrew the T10 12 mm Torx screw.
  • Remove the plastic tab holding the glass in place.
  • Carefully lift the scanner glass panel above the plastic barrier and pull it towards the control panel circuitry. It can take quite a bit of force to get the panel to slide out. If not removed carefully, the scanner glass can shatter
Aggiungi Commento
Slide the new panel of glass in to the tabs on the right side of the top panel. Place your thumb on top of the tab at the top of the panel. grip the outside edge of the panel and roll outward, allowing the scanner glass panel to fall into place.
  • Slide the new panel of glass in to the tabs on the right side of the top panel.
  • Place your thumb on top of the tab at the top of the panel. grip the outside edge of the panel and roll outward, allowing the scanner glass panel to fall into place.
Aggiungi Commento
Reattach the plastic piece which holds the scanner glass down and the 2.74 mm Torx screw.
  • Reattach the plastic piece which holds the scanner glass down and the 2.74 mm Torx screw.
Aggiungi Commento
Conclusione
To reassemble your device after replacing the glass, follow these instructions starting from the removal of the top panel in reverse order.
Jim
Membro da: 06/10/2011
894 Reputazione
10 Guide realizzate
Cal Poly, Team 20-30, Maness Fall 2011 Membro di Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Membri
10 Guide realizzate
If I hadn't already taken mine all the way apart to clean it up good this is all I needed to do to start off with. Good direction step by step. Thanks
ALVIN L MAULDIN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,416
