Introduzione
The scanner is found underneath the scanner glass. If this piece stops moving, you will not be able to scan anything. It may need to be cleaned or replaced at this point.
Cosa ti serve
The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
Both clips will come unattached and you can set the scanner flap aside.
