Salta al contenuto principale
HP Photosmart D110a Ink Cartridge Replacement
  1. HP Photosmart D110a Ink Cartridge Replacement, Ink Cartridge: passo 1, immagine 1 di 1
    • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • There are two pieces to the mouth, make sure to pull down both.
  2. HP Photosmart D110a Ink Cartridge Replacement: passo 2, immagine 1 di 2 HP Photosmart D110a Ink Cartridge Replacement: passo 2, immagine 2 di 2
    • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
    • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  3. HP Photosmart D110a Ink Cartridge Replacement: passo 3, immagine 1 di 1
    • Place the new cartridge into the slot and press firmly until it pops into place.
Conclusione
Altre 2 persone hanno completato questa guida.
Tim Wise
Membro da: 04/01/11
173 Reputazione
7 Guide realizzate
Cal Poly, Team 10-38, Forte Spring 2011 Membro di Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Membri
10 Guide realizzate
2 Commenti
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - Replica
the HP ink cartridge is 60. Does that make any difference???
April -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 35
Tutti i Tempi: 12,176
