Salta al contenuto principale
HP Pavilion x360 14-ba253cl Keyboard Replacement
Cosa ti serve
  1. HP Pavilion x360 14-ba253cl Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Keyboard Replacement: passo 3, immagine 1 di 1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Keyboard Replacement: passo 4, immagine 1 di 1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Keyboard Replacement: passo 5, immagine 1 di 1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
82.362 Reputazione
200 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.303 Guide realizzate
Un commento
Kristen, How is the keyboard mounted to the top panel?
Larry Levy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 76
Tutti i Tempi: 7,000
