Introduzione
Did your hard drive crash? Or are you looking for more speed or capacity from a new hard drive? This guide will walk you through replacing your hard drive
Parti
Nessuna parte richiesta.
Unscrew one Phillips #1 screw from the back panel.
  • Unscrew one Phillips #1 screw from the back panel.
  • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
Aggiungi Commento
Slide the back panel down and pull it up. Slide the back panel down and pull it up.
  • Slide the back panel down and pull it up.
Aggiungi Commento
Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive. Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
  • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
  • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
  • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
Aggiungi Commento
Gently pull up on the plastic tab attached to the hard drive. Pull the hard drive up and to the right to remove it completely from the laptop.
  • Gently pull up on the plastic tab attached to the hard drive.
  • Pull the hard drive up and to the right to remove it completely from the laptop.
Aggiungi Commento
Remove the black SATA cable from the hard drive.
  • Remove the black SATA cable from the hard drive.
Aggiungi Commento
Remove the black rubber end caps. Remove the black rubber end caps.
  • Remove the black rubber end caps.
Aggiungi Commento
Remove the four silver 5 mm Phillips #1 screws from the hard drive. Remove the four silver 5 mm Phillips #1 screws from the hard drive.
  • Remove the four silver 5 mm Phillips #1 screws from the hard drive.
Aggiungi Commento
Remove the plastic cover from the hard drive.
  • Remove the plastic cover from the hard drive.
Aggiungi Commento
Conclusione
To reassemble or replace your hard drive, follow these instructions in reverse order with the working drive.
Altre 2 persone hanno completato questa guida.
Erik Miller
Membro da: 22/04/2014
1.629 Reputazione
4 Guide realizzate
Cal Poly, Team 11-51, Amido Spring 2014 Membro di Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,851
