Salta al contenuto principale
HP Pavilion dv9000 RAM Replacement
Cosa ti serve
  1. HP Pavilion dv9000 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: passo 2, immagine 1 di 2 HP Pavilion dv9000 RAM Replacement, Battery Removal: passo 2, immagine 2 di 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: passo 3, immagine 1 di 3 HP Pavilion dv9000 RAM Replacement, RAM: passo 3, immagine 2 di 3 HP Pavilion dv9000 RAM Replacement, RAM: passo 3, immagine 3 di 3
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: passo 4, immagine 1 di 3 HP Pavilion dv9000 RAM Replacement: passo 4, immagine 2 di 3 HP Pavilion dv9000 RAM Replacement: passo 4, immagine 3 di 3
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
Conclusione
Cal Poly, Team 10-32, Maness Winter 2014 Membro di Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,533
