Introduzione
The guide will show you how to remove the device back plate.
Parti
Nessuna parte richiesta.
Ensure the device is powered down and unplugged.
  • Ensure the device is powered down and unplugged.
  • Turn the device upside down with the battery compartment facing you.
  • Slide the black slider to the right and lift the battery out of its compartment.
Aggiungi Commento
Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
  • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
Aggiungi Commento
Use the plastic opening tool to lift up the back plate and set it aside. Use the plastic opening tool to lift up the back plate and set it aside.
  • Use the plastic opening tool to lift up the back plate and set it aside.
Aggiungi Commento
Conclusione
Chris Apple
Membro da: 14/04/2014
224 Reputazione
2 Guide realizzate
Cal Poly, Team 12-34, Maness Spring 2014 Membro di Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 976
