Introduzione
Replace the optical drive in your HP Pavilion dv6000.
Parti
Nessuna parte richiesta.
Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
  • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
  • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
Aggiungi Commento
Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
  • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
  • The tray will partially pop out of the laptop.
  • Firmly pull the drive straight away from the laptop.
  • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
  • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 7,458
