Introduzione
Replace the LCD in your HP Pavilion dv6000.
Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool. Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  • Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
  • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
Aggiungi Commento
Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break. Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
  • Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
Aggiungi Commento
Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first. Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
  • Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
Aggiungi Commento
Take out the two 3.58mm screws on the LCD at the top (one on each edge). Take out the two 3.58mm screws on the LCD at the top (one on each edge).
  • Take out the two 3.58mm screws on the LCD at the top (one on each edge).
Aggiungi Commento
Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
  • Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
Aggiungi Commento
Let the screen gently rest on the keyboard. Remove the tape from the ribbon. Stop here and check the cable
  • Let the screen gently rest on the keyboard.
  • Remove the tape from the ribbon.
  • Stop here and check the cable
Aggiungi Commento
Conclusione
Altre 13 persone hanno completato questa guida.
Ben Hirsch
Membro da: 05/10/2010
3.589 Reputazione
10 Guide realizzate
Cal Poly, Team 21-33, Regan Fall 2010 Membro di Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Membri
10 Guide realizzate
after replacing my cracked screen the back light does not show again
firelionkofi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 157
Tutti i Tempi: 35,388
