Introduzione
If your keyboard is not responding or you want to add in a new one, this guide is for you.
Remove the battery from the back of the computer. Remove the two 7.2mm screws underneath holding the keyboard in. Remove the battery from the back of the computer. Remove the two 7.2mm screws underneath holding the keyboard in.
  • Remove the battery from the back of the computer. Remove the two 7.2mm screws underneath holding the keyboard in.
Aggiungi Commento
Flip the laptop back over (keyboard side up). Pop the bezel off of the case by reaching underneath it. Carefully remove the three ribbons underneath the bezel which attach it to the computer.
  • Flip the laptop back over (keyboard side up).
  • Pop the bezel off of the case by reaching underneath it.
  • Carefully remove the three ribbons underneath the bezel which attach it to the computer.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Gently lift the keyboard out of the casing by holding the top edge (as shown).  Be careful to keep the lower edge of the keyboard in place as you lift because there is a ribbon attached to the back (marked in red). The keyboard is held in by six small tabs (2 on the top and 4 on the bottom).  Lifting the bevel frees the top two.  Free the bottom four tabs by sliding the keyboard forward towards the screen.
  • Gently lift the keyboard out of the casing by holding the top edge (as shown). Be careful to keep the lower edge of the keyboard in place as you lift because there is a ribbon attached to the back (marked in red).
  • The keyboard is held in by six small tabs (2 on the top and 4 on the bottom). Lifting the bevel frees the top two. Free the bottom four tabs by sliding the keyboard forward towards the screen.
Aggiungi Commento
Remove the ribbon from the computer by pulling straight back (away from the track pad and towards the monitor). Remove the ribbon from the computer by pulling straight back (away from the track pad and towards the monitor).
  • Remove the ribbon from the computer by pulling straight back (away from the track pad and towards the monitor).
Aggiungi Commento
DONE!
  • DONE!
Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
Ben Hirsch
Membro da: 05/10/2010
3.568 Reputazione
10 Guide realizzate
Cal Poly, Team 21-33, Regan Fall 2010 Membro di Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Membri
10 Guide realizzate
Actually, there are three screws in the step 1.
The third one is hidden under the cover for the memory box!!!
Be careful, otherwise the dammage is granted.
harley029 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 91
Tutti i Tempi: 21,804
