Introduzione
All your files are stored on the hard drive. People usually replace them when they need more storage. Before delving into this guide, make sure your computer is unplugged and completely turned off.
Parti
Nessuna parte richiesta.
Locate the battery on the bottom side of the laptop. Slide the release switch and the battery will pop out. Remove the battery
  • Locate the battery on the bottom side of the laptop.
  • Slide the release switch and the battery will pop out.
  • Remove the battery
Aggiungi Commento
Use a Phillips #1 screwdriver to loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer. Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover. Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
  • Use a Phillips #1 screwdriver to loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer.
  • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
Aggiungi Commento
Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay. Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay.
  • Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay.
Aggiungi Commento
Disconnect the hard drive cable from the system board. Remove four 4mm screws from the hard drive case. There are two screws on each side of the hard drive.
  • Disconnect the hard drive cable from the system board.
  • Remove four 4mm screws from the hard drive case.
    • There are two screws on each side of the hard drive.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Chad
Membro da: 13/01/2014
949 Reputazione
6 Guide realizzate
Cal Poly, Team 10-34, Maness Winter 2014 Membro di Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,255
