Salta al contenuto principale
HP Pavilion dv2000 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion dv2000 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 HP Pavilion dv2000 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Remove the ten 8.9mm screws (underneath where the battery would be) holding the keyboard and bezel in place.
  2. HP Pavilion dv2000 Keyboard Replacement: passo 2, immagine 1 di 2 HP Pavilion dv2000 Keyboard Replacement: passo 2, immagine 2 di 2
    • Flip the computer over to the front (keyboard-side up).
    • Gently pop the bezel off by reaching underneath it and pulling up.
    • If you are doing this for the first time, the bezel may require you to exert a little bit more force to remove it.
  3. HP Pavilion dv2000 Keyboard Replacement: passo 3, immagine 1 di 2 HP Pavilion dv2000 Keyboard Replacement: passo 3, immagine 2 di 2
    • The keyboard is held in by three small tabs near the bezel of the computer. Lifting the bezel frees the three tabs.
    • If you are removing the keyboard, the tabs will require a bit more upward force to pull away from the keyboard.
    • Remove the ribbon connecting the keyboard to the computer by pulling back on the ribbon (away from the track pad).
Conclusione
Altre 6 persone hanno completato questa guida.
Erik Muniz
Membro da: 09/09/14
820 Reputazione
3 Guide realizzate
CSU Fullerton, Team 2-3, Bruce Fall 2014 Membro di CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Membri
3 Guide realizzate
Un commento
Many THANKS Erik
I am a computer imbecile. I own a hp pavilion dv2000 that is about 10-12 years old.
I may now be able to FIX it and not have to buy a whole new one
phillip james
Phillip James - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,718
