Salta al contenuto principale
HP Pavilion dv2000 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Phillips #00 Screwdriver
    $5.49
    Compra
    • Flip your computer over, so that the underside of your computer is facing upward.
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate the hard drive casing on the bottom-right corner of your flipped computer.
    • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
    • Screws on hard drive casing will remain in casing after being unscrewed.
  2. HP Pavilion dv2000 Hard Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion dv2000 Hard Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion dv2000 Hard Drive Replacement: passo 2, immagine 3 di 3
    Phillips #000 Screwdriver
    $5.49
    Compra
    • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
    • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
Conclusione
Altre 7 persone hanno completato questa guida.
Erik Muniz
Membro da: 09/09/14
820 Reputazione
3 Guide realizzate
CSU Fullerton, Team 2-3, Bruce Fall 2014 Membro di CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Membri
3 Guide realizzate
Un commento
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,219
