Shut down the computer.
  • Shut down the computer.
  • Disconnect all external devices and cables from the computer.
Aggiungi Commento
Flip the laptop over.
  • Flip the laptop over.
Aggiungi Commento
Locate the gray sliding tab next to the black bar where the battery is located. Slide the gray sliding tab to the left until you hear a distinct click.
  • Locate the gray sliding tab next to the black bar where the battery is located.
  • Slide the gray sliding tab to the left until you hear a distinct click.
  • The inside edge of the battery should pop up.
Aggiungi Commento
Grasp the inside edge of the battery. Lift the inside edge of the battery up to detach the battery from the laptop. Lift the inside edge of the battery up to detach the battery from the laptop.
  • Grasp the inside edge of the battery.
  • Lift the inside edge of the battery up to detach the battery from the laptop.
Aggiungi Commento
Locate RAM access door on the bottom side of the laptop.
  • Locate RAM access door on the bottom side of the laptop.
Aggiungi Commento
Locate the two screws holding down the RAM access cover Unscrew the two screws with a size 00 Philips screwdriver. Note: The screws do not detach from the cover.
  • Locate the two screws holding down the RAM access cover
  • Unscrew the two screws with a size 00 Philips screwdriver.
  • Note: The screws do not detach from the cover.
Aggiungi Commento
Lift up on the screw side of the RAM access cover to remove it. Lift up on the screw side of the RAM access cover to remove it.
  • Lift up on the screw side of the RAM access cover to remove it.
Aggiungi Commento
Gently pull apart the metal tabs located on both sides of the stick of RAM. The RAM stick should tilt upwards.
  • Gently pull apart the metal tabs located on both sides of the stick of RAM.
  • The RAM stick should tilt upwards.
Aggiungi Commento
Gently lift the the RAM up and out of its seat.
  • Gently lift the the RAM up and out of its seat.
Aggiungi Commento
Repeat the previous two steps for the remaining stick of RAM.
  • Repeat the previous two steps for the remaining stick of RAM.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Henry OBrien
Membro da: 04/04/2011
104 Reputazione
1 Guida realizzata
Cal Poly, Team 10-37, Forte Spring 2011 Membro di Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Membri
9 Guide realizzate
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - Replica
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 7,531
