Salta al contenuto principale
HP Pavilion ZD7000 Wi-Fi Card Replacement
Cosa ti serve
  1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 1 di 2 HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 2 di 2
    • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
    • Remove the cover.
  4. HP Pavilion ZD7000 Wi-Fi Card Replacement: passo 4, immagine 1 di 2 HP Pavilion ZD7000 Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
    • For reassembly, note where the black and white cables connect to the card.
    • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
    • Gently remove the card from laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Shantel
Membro da: 04/20/10
545 Reputazione
6 Guide realizzate
Cal Poly, Team 30-37, Garner Spring 2010 Membro di Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
4 Membri
6 Guide realizzate
2 Commenti
Can you upgrade the wifi card?
danoco - Replica
is there a replacement I can buy
Braeden Culp - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 5,451
