Salta al contenuto principale
HP Pavilion ZD7000 Speakers Replacement
Cosa ti serve
  1. HP Pavilion ZD7000 Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Speakers Replacement: passo 2, immagine 1 di 1
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Speakers Replacement, Fans: passo 3, immagine 1 di 1
    • Loosen the eight Phillips screws around the plate to remove it.
  4. HP Pavilion ZD7000 Speakers Replacement: passo 4, immagine 1 di 1
    • Remove the nine Phillips screws from the plate covering the fans.
    • The three screws around the lower fan also hold the fan onto the metal plate.
  5. HP Pavilion ZD7000 Speakers Replacement: passo 5, immagine 1 di 1
    • Lift the plate and lower fan off the heat sink being careful not to damage the lower fan cable, which is attached to the motherboard.
    • Disconnect the lower fan connector from the motherboard.
    • Remove the metal plate and lower fan.
    • The lower fan will easily separate from the metal plate.
  6. HP Pavilion ZD7000 Speakers Replacement: passo 6, immagine 1 di 1
    • Disconnect the upper fan connector from the motherboard.
    • Remove the four spring loaded screws holding the heat sink assembly to the motherboard.
    • When reassembling, ensure that all the screws are equally tightened: thread all screws one turn, then add one turn to each screw in the following order: top left, bottom right, bottom left, top right. Repeat this order until the assembly is firmly seated.
  7. HP Pavilion ZD7000 Speakers Replacement: passo 7, immagine 1 di 1
    • Slide the heat sink assembly including the upper fan out by pulling it down and left simultaneously.
    • When reinstalling the heat sink, ensure it is thoroughly cleaned and the thermal paste (or pads) are replaced to ensure proper thermal contact with the devices on the logic board.
  8. HP Pavilion ZD7000 Speakers Replacement, Keyboard removal: passo 8, immagine 1 di 1
    • Remove the screws holding the keyboard to the chassis.
    • Unplug the wire just below the right screw shown and the small white connector to the left of that screw.
  9. HP Pavilion ZD7000 Speakers Replacement: passo 9, immagine 1 di 2 HP Pavilion ZD7000 Speakers Replacement: passo 9, immagine 2 di 2
    • Do not remove the keyboard yet! There are still wires connecting the two components.
    • The far end of the keyboard bezel may still be held by two screws that can only be accessed by removing the optical drive (as mentioned in Step 9).
  10. HP Pavilion ZD7000 Speakers Replacement: passo 10, immagine 1 di 3 HP Pavilion ZD7000 Speakers Replacement: passo 10, immagine 2 di 3 HP Pavilion ZD7000 Speakers Replacement: passo 10, immagine 3 di 3
    • Disconnect the three ribbon cables attached to the motherboard.
    • The wire ribbons are removed by snapping out the small latches on the sides of the connection components. The ribbons should slide out with ease.
    • See images 2 and 3 for a closer look.
  11. HP Pavilion ZD7000 Speakers Replacement: passo 11, immagine 1 di 1
    • Remove the screws from the motherboard.
    • There are many different sizes and types of screws here. Make sure you are keeping track of where they all belong.
  12. HP Pavilion ZD7000 Speakers Replacement: passo 12, immagine 1 di 1
    • Disconnect the speaker cables from the motherboard.
  13. HP Pavilion ZD7000 Speakers Replacement: passo 13, immagine 1 di 1
    • Slide out the optical drive if it wasn't removed in Step 9.
  14. HP Pavilion ZD7000 Speakers Replacement: passo 14, immagine 1 di 2 HP Pavilion ZD7000 Speakers Replacement: passo 14, immagine 2 di 2
    • Pry the frame off the laptop outwards while simultaneously lifting the motherboard out of it.
    • Go slowly on every side instead of focusing on only one corner.
  15. HP Pavilion ZD7000 Speakers Replacement: passo 15, immagine 1 di 1
    • You can now carefully remove the entire motherboard.
    • Unless you plan on replacing it, handle the motherboard with care; this is the heart of your computer and any damage will cause a system failure.
  16. HP Pavilion ZD7000 Speakers Replacement, Speakers: passo 16, immagine 1 di 1
    • Remove the 3 screws connecting the spearker.
  17. HP Pavilion ZD7000 Speakers Replacement: passo 17, immagine 1 di 1
    • Detach the plastic piece holding the speaker in.
  18. HP Pavilion ZD7000 Speakers Replacement: passo 18, immagine 1 di 1
    • To remove the second speaker simply lift it up and out.
Conclusione
Shantel
Membro da: 04/20/10
545 Reputazione
6 Guide realizzate
Cal Poly, Team 30-37, Garner Spring 2010 Membro di Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,402
