Introduzione
The Hard Drive this computer comes with has 120GB of space and runs at 5400 RPM. Accessing the Hard Drive is simple and requires removing a total of only 4 screws.
Parti
Nessuna parte richiesta.
Start with the bottom of the laptop facing up. Locate the panel covering the hard drive compartment.
  • Start with the bottom of the laptop facing up.
  • Locate the panel covering the hard drive compartment.
  • Unscrew the two 5mm Phillips #0 screws.
Aggiungi Commento
Lift up this external panel by the end with the screws and set it aside.
  • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
Aggiungi Commento
Locate the second plastic panel covering the hard drive. Unscrew the two 4mm Phillips #0 screws holding it in.
  • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
Aggiungi Commento
Lift up this internal panel using the plastic white tab and set it aside.
  • Lift up this internal panel using the plastic white tab and set it aside.
Aggiungi Commento
Grab the end of the hard drive and pull it up to a vertical position. Gently slide the Hard Drive off of the SATA connector. Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
  • Grab the end of the hard drive and pull it up to a vertical position.
  • Gently slide the Hard Drive off of the SATA connector.
  • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
Aggiungi Commento
Conclusione
Shannon
Membro da: 11/04/2013
37 Reputazione
6 Guide realizzate
Cal Poly, Team 13-66, Johann Spring 2013 Membro di Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 434
