Introduzione
In this guide you will learn how to remove the DVD±RW Drive from an HP Pavilion DV2160BR.
Start with the bottom of the laptop facing up.
  • Start with the bottom of the laptop facing up.
Aggiungi Commento
Locate the battery compartment at the rear of the device. There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  • Locate the battery compartment at the rear of the device.
  • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
Aggiungi Commento
Locate the  locking screw which is located in a recessed hole on the underside of the laptop.
  • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
  • Remove the M2.5X3-Lg #1 Phillips screw.
Aggiungi Commento
Locate the CD drive tray release hole on the front of the drive. Straighten a paper clip and push it gently into the CD drive tray release hole.
  • Locate the CD drive tray release hole on the front of the drive.
  • Straighten a paper clip and push it gently into the CD drive tray release hole.
  • The drive tray will pop open.
Aggiungi Commento
Grasp the side edges of the drive tray.
  • Grasp the side edges of the drive tray.
  • Gently pull the drive from the laptop.
Aggiungi Commento
Locate the mounting bracket which is attached to the back of  the drive.
  • Locate the mounting bracket which is attached to the back of the drive.
  • Remove the two M2x3-Lg #0 Phillips screws.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 144
