Salta al contenuto principale
HP Pavilion DV1000 Screen Replacement
Cosa ti serve
  1. HP Pavilion DV1000 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion DV1000 Screen Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over.
  3. HP Pavilion DV1000 Screen Replacement: passo 3, immagine 1 di 2 HP Pavilion DV1000 Screen Replacement: passo 3, immagine 2 di 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion DV1000 Screen Replacement: passo 4, immagine 1 di 3 HP Pavilion DV1000 Screen Replacement: passo 4, immagine 2 di 3 HP Pavilion DV1000 Screen Replacement: passo 4, immagine 3 di 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion DV1000 Screen Replacement, Keyboard: passo 5, immagine 1 di 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion DV1000 Screen Replacement: passo 6, immagine 1 di 2 HP Pavilion DV1000 Screen Replacement: passo 6, immagine 2 di 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion DV1000 Screen Replacement, Media Keys: passo 7, immagine 1 di 1
    • Turn the laptop upside-down again.
  8. HP Pavilion DV1000 Screen Replacement: passo 8, immagine 1 di 2 HP Pavilion DV1000 Screen Replacement: passo 8, immagine 2 di 2
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
  9. HP Pavilion DV1000 Screen Replacement, Screen: passo 9, immagine 1 di 1
    • Remove the rubber inserts with the spudger.
    • Note: When reassembling, notice that the two lower rubber pieces are flatter than the four rubber pieces located at the top of the screen.
    • Remove the screws behind the rubber inserts.
  10. HP Pavilion DV1000 Screen Replacement: passo 10, immagine 1 di 2 HP Pavilion DV1000 Screen Replacement: passo 10, immagine 2 di 2
    • Carefully pry loose the screen casing with a plastic prying tool.
  11. HP Pavilion DV1000 Screen Replacement: passo 11, immagine 1 di 2 HP Pavilion DV1000 Screen Replacement: passo 11, immagine 2 di 2
    • Remove the plug by prying it loose with the spudger.
    • Pulling the plug with your fingers could be potentially dangerous unless you are wearing work gloves.
  12. HP Pavilion DV1000 Screen Replacement: passo 12, immagine 1 di 1
    • Remove the single screw marked in the image.
    • Be careful not to break the clips or pull any wires.
  13. HP Pavilion DV1000 Screen Replacement: passo 13, immagine 1 di 3 HP Pavilion DV1000 Screen Replacement: passo 13, immagine 2 di 3 HP Pavilion DV1000 Screen Replacement: passo 13, immagine 3 di 3
    • Remove the 4 screws marked in the picture.
    • Support the back cover and set it down on the desk. Do not pull off the back cover.
  14. HP Pavilion DV1000 Screen Replacement: passo 14, immagine 1 di 2 HP Pavilion DV1000 Screen Replacement: passo 14, immagine 2 di 2
    • Remove the screws on each side of the screen. There are four screws on each side.
    • Remove the screen.
Conclusione
Altre 3 persone hanno completato questa guida.
Tyler Latour
Membro da: 03/12/14
266 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,363
