Salta al contenuto principale
HP Pavilion 15-AB153NR Battery Replacement
Cosa ti serve
  1. HP Pavilion 15-AB153NR Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-AB153NR Battery Replacement: passo 2, immagine 2 di 2
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Battery Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-AB153NR Battery Replacement: passo 3, immagine 2 di 2
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 510
