Introduzione
If your HP Mini 311 has ran out of memory or you desire to have more memory, change the hard drive on your device.
Parti
Nessuna parte richiesta.
Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
Aggiungi Commento
Slide the battery away from the device to remove. Slide the battery away from the device to remove.
  • Slide the battery away from the device to remove.
Aggiungi Commento
With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
  • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
  • The screws will remain in the shied.
Aggiungi Commento
Lift the memory shield up and remove from the laptop. Lift the memory shield up and remove from the laptop.
  • Lift the memory shield up and remove from the laptop.
Aggiungi Commento
Grab the left black, plastic tab and carefully pull upward. Be sure to pull carefully. Pulling too forcefully may damage the tab. Be sure to pull carefully. Pulling too forcefully may damage the tab.
  • Grab the left black, plastic tab and carefully pull upward.
  • Be sure to pull carefully. Pulling too forcefully may damage the tab.
Aggiungi Commento
Grab a hold of the wire connecting the hard drive and the device. Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard. Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
  • Grab a hold of the wire connecting the hard drive and the device.
  • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 20-4, Maness Winter 2013 Membro di Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Membri
6 Guide realizzate
What size hard drive does this unit take?
Travis Duncan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 36
Tutti i Tempi: 2,866
