Salta al contenuto principale
HP Mini 210-2070NR RAM Replacement
Cosa ti serve
  1. HP Mini 210-2070NR RAM Replacement, Battery and Service Access Cover: passo 1, immagine 1 di 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR RAM Replacement: passo 2, immagine 1 di 3 HP Mini 210-2070NR RAM Replacement: passo 2, immagine 2 di 3 HP Mini 210-2070NR RAM Replacement: passo 2, immagine 3 di 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR RAM Replacement: passo 3, immagine 1 di 3 HP Mini 210-2070NR RAM Replacement: passo 3, immagine 2 di 3 HP Mini 210-2070NR RAM Replacement: passo 3, immagine 3 di 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR RAM Replacement: passo 4, immagine 1 di 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Using your fingers, pull the two white clips (tabs) on both sides of the RAM away from each other. Keep pulling the clips until the RAM pops up
    • Hold the RAM on the edges only. Touching the components on the RAM might damage it.
  6. HP Mini 210-2070NR RAM Replacement: passo 6, immagine 1 di 1
    • Grab the edges of the module and gently lift it from the slot.
    • RAM Cards are designed with a notch on the surface to prevent incorrect insertion into the memory module slot.
Conclusione
Altre 2 persone hanno completato questa guida.
Sean Kuster
Membro da: 10/05/12
91 Reputazione
3 Guide realizzate
Cal Poly, Team 3-23, Amido Fall 2012 Membro di Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,060
