Salta al contenuto principale
HP Mini 210-2070NR Battery and Service Access Cover Replacement
  1. HP Mini 210-2070NR Battery and Service Access Cover Replacement, Battery and Service Access Cover: passo 1, immagine 1 di 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Battery and Service Access Cover Replacement: passo 2, immagine 1 di 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: passo 2, immagine 2 di 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: passo 2, immagine 3 di 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Battery and Service Access Cover Replacement: passo 3, immagine 1 di 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: passo 3, immagine 2 di 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: passo 3, immagine 3 di 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Battery and Service Access Cover Replacement: passo 4, immagine 1 di 1
    • Orient the computer as shown in the picture.
Conclusione
Altre 2 persone hanno completato questa guida.
Sean Kuster
Membro da: 10/05/12
91 Reputazione
3 Guide realizzate
Cal Poly, Team 3-23, Amido Fall 2012 Membro di Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,444
