Introduzione
Replacing the WWAN (Wireless Wide Area Network) card is easy and straightforward.
Turn off and unplug the netbook before replacing the battery. Hold the netbook top-side down with the lid closed.
  • Turn off and unplug the netbook before replacing the battery.
  • Hold the netbook top-side down with the lid closed.
  • Slide the plastic battery release latches towards the lock symbols.
  • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
Aggiungi Commento
Slide the battery out from the netbook.
  • Slide the battery out from the netbook.
Aggiungi Commento
Turn the netbook to view its edge.
  • Turn the netbook to view its edge.
  • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
Aggiungi Commento
Pull the back case off from the front edge.
  • Pull the back case off from the front edge.
Aggiungi Commento
Use a plastic opening tool to disconnect the two gold antenna cables from the WWAN card. Use a plastic opening tool to disconnect the two gold antenna cables from the WWAN card.
  • Use a plastic opening tool to disconnect the two gold antenna cables from the WWAN card.
Aggiungi Commento
Use a phillips #00 screwdriver to remove the 2 phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board. Use a phillips #00 screwdriver to remove the 2 phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
  • Use a phillips #00 screwdriver to remove the 2 phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
Aggiungi Commento
Remove the WWAN by pulling or Slide away the WWAN card out of its slot at an angle.
  • Remove the WWAN by pulling or Slide away the WWAN card out of its slot at an angle.
Aggiungi Commento
Conclusione
Heather Freed
Membro da: 06/10/2012
582 Reputazione
8 Guide realizzate
Cal Poly, Team 9-17, Amido Fall 2012 Membro di Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Membri
8 Guide realizzate
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
rioarayana - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 55
Tutti i Tempi: 4,236
