Introduzione
Replacing memory can greatly increase the operating speed of your HP mini.
Parti
Nessuna parte richiesta.
Power-off the netbook fully before attempting to remove the battery. Flip your netbook upside down, and locate the sliding tabs near the battery. Slide both tabs inward so that the battery visibly moves away from the case of the computer.
  • Power-off the netbook fully before attempting to remove the battery.
  • Flip your netbook upside down, and locate the sliding tabs near the battery.
  • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
  • Release the tabs and pull the battery out.
Aggiungi Commento
Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover. Next, take a Phillips PH1 screwdriver and unscrew the two screws. These screws will not release from the cover once they are unscrewed.
  • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
  • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
  • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
Aggiungi Commento
Carefully push the clips to the side, away from the memory card. Note: The memory module is spring-loaded and will pop out when the clips are detatched. Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
  • Carefully push the clips to the side, away from the memory card.
    • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
  • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
Aggiungi Commento
Conclusione
Jared Cooper
Membro da: 18/10/2013
625 Reputazione
5 Guide realizzate
Clemson, Team 14-1, Benson Fall 2013 Membro di Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 979
