Introduzione
The optical drive (also known the CD drive) is one of the most frequently used parts of the HP Media Center 876x. As a result, damages are common and often replacement is necessary.
Cosa ti serve
Orient the tower vertically.
Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
Slide the side panel out of its notches, and pull it gently off of the tower.
Identify the optical drive.
Pull the molex connectors out of the posterior end of the optical drive.
Altre 2 persone hanno completato questa guida.
