Parti
Nessuna parte richiesta.
Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
Aggiungi Commento
Locate the slider under the right side of the battery. Using your thumb, slide it all the way to the left until the front of the battery lifts up. Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  • Locate the slider under the right side of the battery.
  • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
Aggiungi Commento
With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
Aggiungi Commento
Remove the three 4mm screws using Phillips #1 screw driver.
  • Remove the three 4mm screws using Phillips #1 screw driver.
  • Remove the four 6mm screws using Phillips #1 screw driver.
  • Remove the two 3mm screws using Phillips #1 screw driver.
Aggiungi Commento
Using your fingers, pry off the speaker cover.
  • Using your fingers, pry off the speaker cover.
Aggiungi Commento
Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually. Remove the chrome keyboard cover. Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
  • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
Aggiungi Commento
Locate and remove the two 4mm screws with the Phillips #1 screw driver. Locate and remove the two 4mm screws with the Phillips #1 screw driver. Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
Aggiungi Commento
Using your hands, pull the keyboard out. Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
Aggiungi Commento
Lift the black tab using the plastic removal tool. Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer. Lift the black tab using the plastic removal tool. Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  • Lift the black tab using the plastic removal tool. Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
Aggiungi Commento
Use the  Phillips #1 Screw Driver to unscrew the 5mm screw.
  • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
Aggiungi Commento
Flip over the device so that the bottom side is facing up.
  • Flip over the device so that the bottom side is facing up.
  • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
Aggiungi Commento
Push down and pull out the Disk Drive on the left side of the device.
  • Push down and pull out the Disk Drive on the left side of the device.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Marshall Reid
Membro da: 14/04/2014
473 Reputazione
3 Guide realizzate
Cal Poly, Team 12-38, Maness Spring 2014 Membro di Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 665
